WTH???? Something really strange.
vomari
OK , I think I'm going crazy. I just noticed that my liberty once had a slight lift in the back and now it seems to be the same height as the front. I used to have to stand on my tip toes to dry the top side of the roof, now I don't.
Is this possible? I'm a trippin? Nothing was done since my fuel pump work but even then I hadn't noticed anything out of the ordinary.
Is it possible for the lifts to slip? That is a lift right? :confused:
ThunderbirdJunkie
Bronze Supporter
Newport, KY
Sounds like normal spring sag. KJs sit **** high normally, but if you tow regularly it could kill those springs fast.
By lift..you mean that the rear is/was higher? You're using stock springs?
Sounds like sag.
Robsama
Connecticut, USA
What about gas? Maybe every time you washed it before the tank was (near) empty. Now it's full and the weight of 18.5gal of gas males it sit lower.
I know that sounds kinda dumb, but you never know.
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
This is true.
An '02-'03 KJ's FULL gas tank can be as heavy as 114lbs.
An '04 KJ's gas tank is 121lbs....
An '05-'07 KJ's gas tank.... 127lbs.
If it's a diesel....
a whopping 145Lbs!!! ALL of those are significant weights!
