What parts to add cruise control?
LibertyFever
New Brunswick, Canada
I had the dealership add cruise control to my 04 Liberty. Besides installing the hardware on the steering wheel and the cruise control actuator the BCM needs to be programed.
I'm not positive about the 07 Liberty, if the installation involves messing with the steering wheel "clockspring" then I'd take it to the dealership.
Less than a 30 minute job, easy as doing n oil change
just mount a couple of things and install the buttons on the steering wheel, done
Jeep sells the whole kit pretty resonable
dmnjr
central Wisconsin
I did it. les than half an hour. Just ordered a kit from the dealer. You will only need the steering wheel buttons/wires. The 07 has an electronic throttle control. I disconnected the battery for half an hour, then removed the two bolts holding the airbag in, after that added the buttons.
TruLiberty
Northern Virginia, US
how much did having the stealership do it run you?
