Water leaking into car! Help?
JimsRadJeep
Darwin
As the title says, I have a water leak SOMEWHERE that is causing my carpet in the driver's footwell to become soaking wet.
It's the wet season here in Darwin now and I have to park my car in the open where I live.
Without pulling any trim off yet I can't tell where the water is coming in from.
All I can see is that the rubber seals around the driver's door all seem to be where they should be and in good condition.
My guess is the water is running down the windscreen and in behind that moulded plastic section between the windscreen and bonnet and then somewhere though the firewall??
I'm really hoping someone can tell me this is a known problem with an easy fix! I know I'm dreaming but it was worth a try.
Cheers,
Jim
could be that. I think Tim had that issue.
Do you have a sunroof?
There are drains in each corners. If they're clogged, they'll overflow and flood your floor.
JimsRadJeep
Darwin
No sunroof...
Well I will do a proper search on here and google later (when I'm not at work supposedly working).
Was just optimistic that I'd get an easy answer haha.
Boomhawr
North Texas
If passenger side, I was going to suggest maybe a leak in the heater core, but then it should smell like antifreeze, plus you said drivers side. Good luck and let us know what you find.
The KJ looks RHD in his avatar, so his drivers leak=passenger leak and his toilets flush the other way. :D
Although on a RHD one, is the heater core still on the right?
GunnerSchenck
I'd take a good look through this thread, do a couple hose tests, if possible with that side slightly lower and the front slightly lower.
If you can't find it, might want to check the cowl area
There's a sticky in the top links of this section, but yours may look a bit different, being Right hand drive as HJ has stated.
Here's a link for places to check, but this seems less likely since it would probably be on your passengers side
http://www.jeepkj.com/forum/f196/water-leak-passenger-side-quick-fix-54496/
