Warning light help - ESP/BAS & ABS
claggie
Castle Pines, CO
I have a 2006 Liberty with about 42,000 miles on it. The following three warning lights all just came on:
ESP/BAS
ABS
Traction control light in the center
Any ideas?
Irishguy24
Orlando,FL
one of your wheel speed sensors has gone bad, the code will probably tell you that, they run about 15- 20 dollars a piece, When it happened to me, I replaced all 4 at one time, very simple to do
claggie
Castle Pines, CO
So, it was the driver side wheel sensor. The rivot that held it in place was missing and it looks like it wore against something and was causing it to short sometimes. The warning lights came on and off periodically during the 10 days before I got it into the mechanic.
Easy $50 fix, part and labor. Good to go now. Thanks for the advice.
