L
lil black liberty
Guest
Okay I just installed the Mopar Fog Light kit and someone on the Forum here had said to put the violet wire on to the black/yellow wire on the turn signal in order to have fog lights while your highs were on. The problem is on my Turn signal it has a black, white, Red plug there isn't a black/yellow. The fog lights won't turn on at all and here is where I have it grounded
underneath that screw and under the plastic directly on the metal.. is that a good place to ground?? Also the reason I couldn't do as the mopar instructions said was because I can't pull the wire out any farther in order to slice into it... Any suggestions??!!
