Transmission Oil Change for $300???
benji_KJ2003
I just had an appointment with the dealer to change&flush the transmission.
Is this a fair price?? I heard my friend got his Accord changed for $90.
Why it cost me that much???
jeepkj02
Holland, Michigan, USA
Don't do it!! Changing the ****** fluid is not too hard, just drop the pan, change the filter, reseal and refill. No flush necessary.
benji_KJ2003
Thank you very much. But I've heard that if DIY, I can only get 30% of the old fluid out of the transmission. Is that true?
benji_KJ2003
If you just drop the pan only 5 qts out of the 17 qts (?) of ATF+4 fluid. How many miles does you KJ have?
Thanks a lot, jeepkj02.
I had 85000km on my 03 KJ.
You mean all the transmission fluid will come out completely once the drain plug is turned off ??
libertyman
The dealer told me $217 CDN to flush the ******, and Mister Transmission told me $79.00 WTF? also the dealer said when you flush the ****** you do not need to change the filter?
kjpilot
Minneapolis, MN
You can't buy the filter & 5 qts of ATF+4 for $80. Mr. Transmission is cutting corners!
kjpilot
Minneapolis, MN
It's kind of high, but I don't think you got screwed. Even to do it yourself, you will spend about $100 on fluid, filters, RTV, & clean up products. then the labor is a pain. I'd shop around next time, but I don't think that price was terribly out of line.
$25 for 5 quarts of Mopar Atf+4 at walmart, buddy gave me a filter and gasket.. Im set.. :D
I do not use RTV anymore.. Gaskets for the ****** and rear diff.. :)
benji_KJ2003
Thanks guys. I dont have my own garage to do the trany stuff. So I will spend $300 to have it done. I wish one day I could DIY. It should be more fun than changing the engine oil.
kjpilot
Minneapolis, MN
Yep, then about $55-60 for filters, plus whatever you pay for whatever you place between the pan & transmission... more than $80
oh, you got the filters for free!:eek: Hope you can do that next time!!!
SRotblat
LOST #666
I got my filter for $30 from the dealer....hoping to do the oil change this week (first one at 85k - doh)
