Transmission Failure
YungAsianGentleman
There are 4 codes for transmission errors on my 06 Jeep KJ
PO700 - Transmission Control System Malfunction
PO732 - Gear 2 Ratio Incorrect
PO734 - Gear 4 Ratio Incorrect
PO736 - Reverse Ratio Incorrect
The Jeep will not move for a few seconds after stepping on the gas, then will start to kick into gear and go, then struggle to kick into the next gear, and it gets stuck in, what i believe to be 3rd gear at 40mph or so, and running at 3500-4000rpms. The Reverse also has the same sort of problems.
I have a buddy who believes it's the transmission control system that's causing all the other problems and codes. I am not too sure about his diagnosis, so I am wondering if any of yall have a possible diagnosis of the underlying issue of my transmission failure from the information given above.
How many miles on this KJ transmission ? Does the ATF + 4 transmission fluid smell burnt ?
Is the fluid level on dipstick correct? Have you tried adding an extra half quart of ATF +4 fluid ?
joshgoble
Setting on 37x13.5x 17
Baird TX
It sounds as though you have a valve body issue I would rebuild it or replace it The transmission or the computer itself should put it in the limp mode and it should only take off in a second and stay in second trying to protect the transmission. But they're notorious for bad valve bodies.
joshgoble
Baird TX
Have you had any issues with the torque converter staying locked in and it not coming out of gear
24turbo
Alberta Canada
If the level is fine, drop the pan and see whats in there. There is a small chance you filter is plugged and changing it will fix it. You can change the shift solenoid also as it may be giving trouble as well.
BUT....
My interpretation of your codes:
The transmission has sensors to measure shaft speed at input and output of the transmission. The computer can calculate shaft speeds based on which gear it is in, and if the input vs. output speeds dont match to the calculation, it assumes there is something slipping in the transmission (which is usually the case).
Gear 2 and Gear 4 share a clutch so that is a common point which leads me to believe the 2/4 clutch is toast. This should not affect reverse but there are 3 other clutches in the transmission which may also be affected somehow.
Jeremy-WI
Home
Be sure to check the transmission fluid level after driving it for a while with the engine still running
nbas
Greece
I had P0700, P0732, P0734, P0736, P0841, P846 and finally I had to rebuild the transmission. They said that a snapring failed and caused the issue. The oil was red, as I change regularly, but there was silver powder in the oil...
