Transfere case
Pt420
I have a 2007 Jeep liberty limited and a 2003 Jeep liberty sport the 2003 has only 77,000 miles on it and was wondering if the tansfere case from it can be put on the 2007 limited. First photo is from the 2007 the second is from the 2003.
klc
“It flies like a truck.”
PNW
Have you tried looking up the build sheets? They list that sort of thing.
Photos , what photo
2003 rear diff has the speed sensor built into it
The 07 has ABS so that is different
then gearing depending on what transmission is in each one
Pt420
Photos , what photo
Sorry I any transfare case.
Pt420
Photos , what photo
I don't know I attached to this several times they are coming upon here. I also I meant transfere case worded it wrong fixed it.
Pt420
OK NOW depends on what transfer case is in each one
2 different ones
what does it have on each handle in the cabin
Pt420
2 different ones
New at this been working on replacing the transmission so when you ask "on each handle in the cabin" what is that you are asking for? I posted the picture of the part number of both of them. I am assuming they are different. The 2003 goes with the transmission I am putting in I was told by a mechanic this ****** works with my 2007 jeep just trying to figure if the transfere case will to.
LOL
OK on the handles to put into 4 wheel drive what letters does it have
I am not looking up parts numbers on each
and transmissions maybe different since they did some changes during 03 model year
Pt420
Thought is what I thought you where saying get back to you tomorrow will check both out I know both handle are same place look exactly the same as for letter I will get back ya ya on that. Thank you.
Pt420
2 different ones
Both are exactly the same. 2Hi-4Hi-N-4L P- R-N-D-2-1 both in this order
LOL
2Hi-4Hi-
turblediesel
memberable
Alaska
You have the Selec-Trac transfer case with full-time 4wd. (ignore me, I'm wrong)
beelatch
Tampa, FL
Years ago I did a 2005 CRD complete swap into a dead 2002 3.7, and I mean COMPLETE, including everything except for the sunvisors and the windshield washer reservoir. It all swapped directly in except for those two parts AND the transmission cross member mounts. The 2002 was straight and the 2005 was angled, sort of like a boomerang. We had to cut the transmission mount off of the 2005 cross member and replace/weld it onto the 2002 cross member. The difference between the two was a model year change, not diesel to gas model difference. You may have to take that into consideration.
