Tires
mattjeep
El Paso, TX
I know that this has been covered before but I need some opinions. I want to lift my KJ with either the Rusty's full coil lift or the Franken Lift. Mine is a 2006 and I want to put on 275/70/16 and I know that I will have to do some trimming but is it possible to fit that size on there or if thats going to be to wide than I could go with 265/75's.
The 275's will be 10mm wider than the 265's,I run 265's and only rub in the front off the rear wheelwell's at full flex.No rubbing up front but I do have a ARB bumber,had to pound the pinch weld over and major bumber cutting with the factory bumber.
mattjeep
El Paso, TX
So you think 265 would be better? As far as full flex I hardly go offroading with it and if I do it's easy stuff nothing that would test the articulation of my KJ.
