throttle body gasket
Nooby
VA
since I had never cleaned the throttle body before, i figured it might be best to remove it, so I can clean the back side of the plate better,
my question when looknng at parts there are 5 gaskets listed on rockauto
http://www.rockauto.com/catalog/x,carcode,1386862,parttype,6474
anyone have any advice, it looks like the first 2 might be for the IAC, but i don't know,
from looking at other sites this might be the one I need
FEL-PRO Part # 61225 More Info
Power-Tech engine; Mounting
thanks for any help
moparpartsameria has one for 17$plus 10$shipping
FEL-PRO Part # 61324 More Info
Power-Tech engine; Idle air control; 21mm ID
FEL-PRO Part # 61326 More Info
Power-Tech engine; Idle air control; 30mm ID
VICTOR REINZ Part # G31637 More Info {#53013292AB}
AIRTEX / WELLS Part # 1G1123 More Info {#53013292AA, 53013292AB, FG66}
huntbuggy
Ottawa, Canada
Pretty sure you've got the right parts - the main gasket and the ones for your two sensors TPS and IAS probably. Should likely only need the main throttle body gasket (2002 was OE part 53013292AA) but at the price might want to get the others and spares.
If you're shopping at ROCKAUTO use their 5% off code 45853253761045 in the "How Did You Hear About Us" at checkout.
Nooby
VA
thanks for your help,
yeah, I probably will pick up the first 3
that way I have them if I need them,
