Rchobbit
I put an 05 motor in an 03 liberty. I changed out the ring on the crank shaft and the gear on the cam. The old motor would run when I took it out and the gas pump worked. Now it appears the engine is not getting fire and the gas pump is not getting power. I can jump across the relay in the fuse box under the hood and get the pump to work. When I hook a code reader to the connection under the dash I get a check DLC connection. Not sure what that is. Can anyone help with these problems? Thanks for all responses in advance.
