Speed knocking
liron sasson
Hi guys
2006 3.7
I have low knocking while driving at 35-65 mph 1 knock per second.
Every time i hear this noise at another speed and somtimes its gone...i removed the front drive shaft and it was the same.
What do you think?
Front CVs , Intermediate shaft
Sway bar end links
can you tell if front or rear ?
Ksat
ny
liron sasson
This is the noise I hear, not the noise of the friction but the knocking noise is the same.
Above he is saying bearing noise ? I assume he is referencing wheel bearing , but ???
Does it make a difference which way you turn
If you turn right and more nise then left bearing, and if you turn left , it is right bearing
But i hear no difference from video so going back to a CV
I meant the knocking sound..boom boom boom
Not the bearing noise
And I think that was what Red neck 10 thought he was referring to
I don't hear any bearing noise , just what I assume as CV noise on the video
Of course trying to locate a noise on video is like listening to a cat scratching the door, hard to tell where it is or anything else
