eddiev9 said:
By the way, what's in your dash location?
If you are talking about the dash speaker location.......if you noticed I listed the db6500 not the db650s the one I have are the component set up with 2 woofers, 2 tweeters and 2 crossovers. I have the tweeters from the front set in the dash and the tweeters from the rear set mounted on each side of the flip up rear glass.
I used strap iron to mount the tweeters in the dash was real easy, that and I ended up using the factory door speakers as adapters by cutting them apart since the the hole in the door is bigger than 6.5" they say it is.
As far you saying you needed all the room you could get, I kinda killed my room in the rear when the sub when in (but oh how I love the blured vision (biggrin) ) , adding a couple more amps (mounted on the back of the rear seats won't hurt me more space wise much. I do need to start looking at a bigger altenator though, I think 3 amps are gonna push the stock one a bit.
