Spark plugs @ 90k miles
WesChapman
N Idaho
I'm concerned about the build up on the base of the threads. one plug had wet oil on it, but the coil and o-ring were dry so it's not leaking from above the plug and dripping down.
ptsb5a
Northern Alberta, Canada
Could just be old anti-seize. The electrodes look fine, they're not all gunked up.
Did you post pics of the oily plug? The ones you did attach don't look too bad.
jnaut
Seattle
That greyish stuff definitely looks old anti-sieze, but I'd be concerned about the 'wet oil' that looks like it's gathered on the stop ring on that first pic. Maybe what TBJ said?
WesChapman
N Idaho
I didn't see any oil leaking, however, the oily plug came from the passenger side, but now I forget if it was the rear plug, or middle. I didn't look real hard for a leak since the coil and o-ring around the coil were dry. Next time the hood is up, I'll look closer.
I didn't use anti-seize when I changed the plugs the 1st time. This is only the 2nd plug change, the 1st didn't happen until 60k. (FYI:60k on OEM plugs, not recommended. They were in bad shape)
