Skid plate set deal
mindbomb
California
Is 170$ a good deal for a used set of Mopar front, tcase and gas tank skids ?
I got a 2003 Libby
Thanks
They would've had to. You can also mod a newer one, just a matter of drilling a few holes I think.
$170 is ok if shipping isn't terrible. I think I paid $250ish for all of mine new from the dealer.
yeah. just need to drill one hole for the nutzert.
i still need to do mine.....
but i dont think the stock 03 came with a ****** skid. Mine didn't come with one.
I truthfully didn't think they came stock at all...
99% didn't. You needed the optional off-road package to get OEM skids and then you also got hooks and trac-loc and rock rails. That's what it says in my 05 sales brochure. Mostly I think that package was ordered on a very few Renegades from the factory. (02-05 models.....not sure about 06-07)
There was a ****** skid also that was in the OEM factory skid group and it is not in that pic. The ****** skid was a little flimsy. The rest of them were better.
I think they're worth $125-max used with no shipping if you can get them local like that. They look like they need to be sanded and painted from the pic.
mindbomb
California
Hey thanks everybody for the advice!
I got them all for 135$ SHIPPED! I think it's a pretty good deal.
It doesn't come with any mounting hardware - so any advice on bolt/nuts types/sizes/counts or other stuff I'd need would be great.
I'll definitely sand them a bit and spray with black primer before mounting.
CzarKJ
Townsend, MA
Hardware shouldn't be an issue. If you did the recall for trailer hitch you have the bolts back there. For the tcase you might have to drill through the cross member and just put regular bolts.
Part of my build sheet:
ADLP Skid Plate Group
AHMS Convenience Group I
AHT Trailer Tow Group
AWL Off Road Group
A33P 3.7L Eng(EKG)/4Spd A/T 45RFE(DG4)
DG4 Multi-Speed Auto 45RFE Transmission
DHAP Lock-Up Torque Converter
DHPP Selec-Trac Full Time 4WD System
DJJS Dana 30/186MM Front Axle
DMEP 3.73 Rear Axle Ratio
DRAP Corporate 8.25 Rear Axle
DSAP Trac-Lok Differential Rear Axle
NMCP Heavy Duty Engine Cooling
SDAS Jeep IS43 Suspension
XEAP Tow Hooks
XEEP Fuel Tank Skid Plate Shield
XEFP Transfer Case Skid Plate Shield
XEUS Front Suspension Skid Plate
XFJP Class III Receiver Hitch
XFKP 7 Pin Wiring Harness
XFLP 7 to 4 Pin Wiring Adaptor
Unfortunately the front suspension skid and the tow hooks were no where to be found when I got it. :favorites68::favorites68::favorites68:
Fired
...Unfortunately the front suspension skid (Jiffy Lube forgot to put it back on) and the tow hooks (mom snagged her ***** hose on them while carrying the groceries in and had "those dangerous fishhooks" removed) were no where to be found when I got it...
If you bought it used, that's probably what the previous owner allowed to happen.
Leeann
Maryland
You need a rear tow hook, come to Annapolis and get it. It's sitting on my picnic table ;)
My export 04 Rocky Mountain came with all factory skids (except transmission skid) was not listed as an off road package, instead a "Skid Plate Group"
I added the factory trans skid and part number is in photo, if you want to add an OEM one..
57714[/ATTACH]"]
Comes with hardware/nutzerts etc.
