Liberty For All
The lube Tech at the local oil change garage stripped the lower drain nut on my 6 speed transmission and can't drain the fluid. How long is OK to just leave the fluid in if it was refilled over 20k miles ago? Has anyone tried suctioning the fluid out of the Fill Nut above the Drain Nut? Should I just not worry and drive on? I don't tow or do off road much. What is your informed opinion?
