I changed my 45rfe transmission filters this morning. I used my torque wrench set to 18ftlb to tighten the transmission pan bolts as that was a value I found in some research. One bolt started to feel weird, never felt tight at all, then the head sheared off. I was ultra careful after this but this ended up with 4 out of the 15 bolts with sheared off heads. They're pair together on the passenger side and a pair together on the driver side.
The 4 that sheared never even felt like they were getting tight at all, but loose, loose, loose, snap. I'm confident I didn't just crank on them.
I can just let the RTV set overnight and then hope for the best in the morning. Any better ideas?
edit: with such a systematic failure perhaps the torque was too high...some other sources say 105inlb or 12ftlb so perhaps I 150% them
