Seat Height
Thelt
Lenoir, NC
The driver's set sits a little higher than I would prefer. Is there a mod someone has done to lower it? Do limited models have power seats that adjust the height?
NJallDAY
New Jersey
Im 6'3" and had the same problem but i got used to it. The only seat mod i have seen so far is to give you extra leg room.
martin_metal_88
Quebec,Canada
you could try to remove the seat and trash out some mounting hardware but I have no idea how it would turn. Only other idea is to get an aftermarket seat that is lower.
Thelt
Lenoir, NC
Maybe I will just get used to it as well. I am not very tall so head room is not an issue. It just feels odd to be up so high.
NJallDAY
New Jersey
It was the same for me. First thing in the morning was the worst but by the end of the day my spine compressed enough to make it much more comfortable lol. Play with the seat adjustments too i have mine dialed in to where it doesnt feel like your so high up.
Thelt
Lenoir, NC
I have not found any adjustment that changes the height. All you can do is move the seat forwards and backwards and recline the back of the seat. I don't have power seats. I wonder if I could take my seat bracket to a local shop and have them cut an inch or two out and weld it back together?
NJallDAY
New Jersey
I didnt mean an up/down adjustment. I just found a good combo of the 2 adjustments to keep my line of sight bellow the visor. I was thinking about cutting and welding back together but i just didnt care that much. I went from driving a vw passat to the jeep so the position was very diff. Before you go cutting the bracket up ans spending money you should probly give it a couple weeks and maybe youll get used to it like i did. Thats just my 2 pennies. Anyway good luck with it
Edit: just remembered another reason i didnt shorten the bracket. The supports dont go straight up and down theyre on a slight angle so it would take more then just a simple cut and weld to make them line up proper
