Scheduled Maintenance Records?
NVMY03GT
All -
We have a 2002 Jeep Liberty and I'm fighting the ever so nice Gas Mileage issue - so since we switched to winter mode naturally the gas mileage is even worse.
We are 62k right now - what is recommended per Jeep/Chrysler ? 30k 60k etc?
hyde
Recommended what? A/B Maintenance?
NVMY03GT
No meaning you know how most car manufacurers say change your belts and such at 60k. What is Jeeps interval?
jeepkj02
Holland, Michigan, USA
I would check/replace the following:
Check/Replace spark plugs
Change front/rear axle fluids
Check/Replace air filter
Check/Replace PCV valve
Check/Drain transmission fluid (ATF+4)
Check Serp. Belt
Change T-Case Fluid (ATF+4)
C.W.
Phoenix, AZ
..which is exactly what I'm going to do. Here's the list--please check and comment. Thanks!
2005 RENEGADE (not limited slip, 6 spd manual, command-trac)
Air Filter:
AMSOIL Ea Air Filter EAA201-EA
PCV Valve
FRAM Part # FV408
Spark Plug
Autolite Ignition XP5224
Oil & Filter
Mobil 1 Truck & SUV 5W-30 /Mobil 1 Extended Performance Oil Filter
Front & Rear Axle Gear Fluid
Mobil1 Gear Oil: 75W140 Synthetic
Power Steering Fluid
Mopar Power Steering Fluid
NV231 (Command Trac) Transfer Case Fluid/Filter
Valvoline ATF +4
NSG370 Transmission Fluid (no filter)
Amsoil Synthetic Manual Synchromesh Transmission Fluid (MTF)
2005 LIMITED (auto, select-trac)
Air Filter
PCV Valve
FRAM Part # FV408
Spark Plug
Oil & Filter
NV231 (Select Trac) Transfer Case Fluid/Filter
Valvoline ATF +4
42RLE Transmission Fluid/Filter
Valvoline ATF +4
