CCKJ03
Is it normal to have no threads showing when you torque down your the nuts on the studs for the mount plate? I know the OTT plate provided will shorten the distance you have for running down the nuts. I just wanted to know if this is normal and has anyone experienced problems? In addition, my rear shocks squeak pretty well. I have down everything imaginable to try and stop the squeak, then I notice when I had them disconnected that the 12mm sleeves provided by RRO had warn out real bad. Has anyone experienced this? lastly, if so what did they do to correct it?
