Rotor Removal
timinator
PA
Hi, I'm replacing the front rotors on my 02 limited. I removed the caliper assy but the rotor wont budge. I've doused it with liquid wrench and have given some raps with a mallet but no luck. Any suggestions?
Thanks
Tim
Hit it alittle harder? I always worry about the bearings when doing that, but idk what else you can do other than taking it to a shop. Is that liquid wrench youre using penetrating spray? Let it soak a good hour or so and make sure your using penetrating spray...
DougBenn
Make sure the retainer clips are removed from the front studs first.
Then tap the sides of the rotor with a hammer, If that doesn't then tap the face of the rotor with a large deadblow hammer.
timinator
PA
I got a little more aggressive with the sledge hammer and got it off! I hit it straight on and to one side. Not something I felt comfortable doing but it worked!
With new pads and rotors the braking is smooth as silk.
Thanks
