Right rear shock making a strange noise
Ethan05
The passenger rear shock is making a strange thud or thumping noise when driving, especially over bumps. I recently had the shocks replaced. The left rear sounds fine. Has anyone had issues like this?
Hec In Omaha
Beaver Lake, Nebraska
Ok
Make sure the rear spring is sitting on its perch and that the rubber spring isolator is in the correct position . Have someone rock the Jeep back and forth while you are under the Jeep. Maybe you’ll hear the noise and see the problem.
Hec
Ethan05
Ok
Hec
We’ve moved the spring to the right spot before trying to find the problem but it didn’t seem to help. We also have rocked the jeep a bunch but it doesn’t make any noise.
Hec In Omaha
If you still have the old shocks compare the diameter of the upper and lower mounting bushings to the new shocks and make sure they are the same. If not you may need to install a bushing sleeve.
Hec
Ethan05
Hec
I do have the old shocks still and will check that out tomorrow. My main concern is why would it be the right side and not both?
Ethan05
Could be weight distribution, rear spring condition, etc. Also check lug nuts for tightness. Ya never know!
Hec
Alright I appreciate the quick responses! However, we took the whole wheel off not too long ago and looked at everything to see anything out of the ordinary but it seemed fine. We torqued the wheel back on too
Check the torque on the sway bar links as well. Maybe the shop disconnected them while installing the shocks?
Back in the day, it was a common issue that aftermarket shocks had a slightly shorter sleeve. The fix was to over tighten the bolt...
Ethan05
It was my uncle that actually replaced them and I was there. They didn't mess with anything other than the shocks from what I seen but I can double check.
Ethan05
I read that the torque specs were around 80-90lbs, but we double checked and torqued them to around 100lbs I believe
ikuo78
Japan
Unlikely, but could the shock be upside down?
Faulty shock perhaps, if you still have the old ones swap it out, then you can look at it compared to the other one and see if the noise dissappears.
Are your bumpstops still in place?
David A. Warr
I had a similar problem with the driver’s side shock. The shock was loose even though the bolt was completely tight. I discovered that the bolt was actually worn. A new bolt fixed the problem.
Ethan05
Hec
the bolts are fine it seems.
The diameter of the new shocks bottom mount is smaller than the old ones. We put some spacers on the bottom and it seemed to help a bit, but there is still a bit of noise. I will be looking into getting a bushing sleeve to fit the space needed. Thank you all for the help
