Replacing Head Gaskets
KingKJ
The Rock Spotter
Utah
So pretty much I discovered this last week that my Liberty is burning oil at a quick rate and it is most likely a head gasket issue. I had to drill holes above the cats after a vacuum line failed and I've been getting small amounts of oil leaking from the holes I drilled as well as when starting it spews smoke out the exhaust. Luckily the gasket is not completely gone and I'm not getting any coolant mixing with the oil. I'm just wondering any tips about how to go about replacing the gaskets and any parts that I should look into replacing, checking, or potentially upgrading while I have the heads removed from the Jeep. I don't plan on digging any deeper than the heads unless I discover problems with the pistons/piston rings which then I'll probably have to take the motor out in order to continue on the repairs.
u2slow
BC
If the gasket has failed, you very likely need the head surfaced. It sux, but that is the nature of aluminum.
I used the felpro blue gasket. It was 1/4 the price on Amazon vs my local auto parts store. I also only did one side.
KingKJ
The Rock Spotter
Utah
Alright, I'll have to see once I actually get it off how bad the gasket is, but I don't think it's all the way dead just because I'm not mixing coolant yet so I'm assuming the gasket hasn't completely failed, but it is starting to fail. Also I plan on doing both sides just because they are both 225k miles old and in order to get to the side that I think is the problem, I remove everything anyway so I don't see why I would bother with doing one side when I'll clear most of the stuff anyway.
Are you sure this is a head gasket issue? Is one plug oily? Have you checked the compression and looked at the valve guides and stem seals?
At 225k you are probably looking at a very worn set of pistons and bores.
u2slow
BC
I managed to do the one head (passenger) without removing the ps pump, water pump, or opening the timing case.
It isn't the prescribed method, but it saved me time and incidental parts. This was at 305k, and it had dropped a valve seat. YMMV.
Edit: aluminum heads typically distort from heat, and that causes the HG to lose its seal. It is unusual for a MLS gasket to fail/deteriorate on its own accord. That's why it's important to get the head surface true again.
KingKJ
The Rock Spotter
Utah
We just replaced the spark plugs and the engine is also throwing misfires still, haven't checked compression, the valve guides and stem seals will be looked at during the teardown process. I'm hoping the pistons aren't too bad, but I'm also a bit worried just because of age and the fact I've driven while overheating twice.
KingKJ
The Rock Spotter
Utah
Honestly didn't know those are prescribed to come off lol, I was talking about all of the stuff that's located on top of the engine that us visibly in the way.
u2slow
BC
The FSM wants you to tear it all down so you can access the chain and tensioners - preferably renew them also. And gain access to pin the tensioner back for reinstalling the cam sprocket. I managed to jig the tensioner business with a coat hanger and mechanics wire from above.
Stromberg
Can you elaborate on your method? I’m replacing a head this weekend and really like the idea of not messing with the timing cover.
CheddarGau
Lower Mainland BC
Ok so first things first. Pull the cover. It's not hard. This give your the opportunity to check your guides and replace anything that needs replacing. Balance shaft is a little tougher, but still not hard. No special tools are required, all you need is a crescent wrench to hold the cams when you torque the cam sprockets. Attempting to leave the cover on generally results in leaks and doing a job twice.
Basically you are going to set your cams and crank to TDC. Then pull the front cover accessories. I left the AC compression and power steering pump hoses on and moved to the side. pull front cover, retract tensioners (cams only, I also like to make the chains on the cams for re-intall). Leave chains on the crank, but keep tension on the chains and crank with bungee cord if you are worried about them falling in off. I just let me go down, which didnt matter since they were still on the crank sprocket. If you break exhaust bolts in the head don't worry, they are easier to get out with the head out. It's honestly one of the easier heads to do. It's quite a primitive engine, and almost enjoyable to work on.
u2slow
BC
I studied this video to see how the tensioners worked and how to pin it.
Fishing line is small enough to pull the chain taught and still let the cam sprocket full engage.
Use some smallish levers and pry bars to arrange things down thru the block and head cavity... and also to pop out the wire used to pin the tensioner.
KingKJ
The Rock Spotter
Utah
well good thing I'm doing that anyway, Just discovered the oil leak coming from there lol, still have head gasket issues, just now also have to do the gasket for front seal/timing cover/ something leaking oil in front of engine
Stromberg
How is the tensioner getting pinned if you never take the timing cover off? I know how the little ratchet deal and pin work but can’t visualize what you’re getting at here.
u2slow
BC
Push it back with a prybar from above. Bend wire into a long L shape and force it into the little hole to pin it.
