Replaced front suspension
gummie45
Replaced front suspension, ball joints, inner outer tie rods, etc. test drove about 20 feet and right front wheel felt like it was wobbling. took both wheels off and only thing I saw was inner tie rod boot was drawn up toward large opening on boot. this was on both sides. Recheck torque and took another test and same thing. Any sugestions?
blackhawk
Venezuela
Did you check your upper control arm? Maybe you might have a bad ball joint.
gummie45
Yes, I checked ball joints no play. Could one wheel being way out of alignment cause this?
UPDATE: Rechecked everything. Found upper control arm on passenger side bolts were loose. Was able to get in for alignment. Now all is good. Thanks for all the help!!
