Remove pilot bearing on shaft with engine swap??
jeepbeep
US
Manual going in to auto '03.. Everything works except torque converter is held up by pilot bearing or "bushing" on the manual-engine shaft and no puller or grease seem to work. How did others past this? I've read people got it off but no descriptions..
Heavy Irony: This never gets a descriptive or experienced answer like all the "yes" answers to the 'will a 2003 manual engine fit in a 2003 auto?' question..
jeepbeep
US
It's a bearing, not a bushing. When I did my clutch job, I used the bearing puller that Autozone has in their free tool rental. This guy: Pilot Bearing Puller Attachment for Cars, Trucks & SUVs
I've used the grease/dowel/hammer trick to remove a pilot bushing before, but I don't see that working nearly as well on a bearing which can ooze through.
It's been called both on the net even though you're right. I got it off. It can be drilled or you can swap output shafts too.
