TomO
I'm looking deeper into Nancy's radiator fan problems. She's an '04 3.7L with only the electric fan.
I see that there are two relays. One for high speed, the other for low. The problem is that coolant temp starts to rise when AC is on and speed is low. Idling in the barn with AC on, the fan did not run last night. I swapped each relay with the blower motor relay and confirmed that the blower motor does power up. I also confirmed that fuse #2 is still good ( it was blown the other day ). I did see the fan run that day, but I don't know which speed it was running at.
Are any of you familiar with the logic involved in this? What conditions must be met for the low speed vs. high speed operation?
Does the ECU provide a ground through something like an open collector output for each relay coil, or does it switch +12v to each relay?
I'm trying to find some good test points to try and determine when / if a run fan signal is being sent. Any help would be greatly appreciated.
