Question ? 15 x 7 w/ 31 10.5 x 15 work ?
John3seventeen
WV Panhandle
From everything I've read 15x7 aftermarket steel wheels like Cragar soft 8's with 4" backspacing will work.
All depends on how it is lifted
spacer lift - more than likely not
full spring lift, possibly depends on tires, tread design etc
30 inch tall is better
will you lose power/mileage ? OH HECK YES!
aftermarket, 4 inch backspacing only not stock wheels
and please fill out the specs on what year/ what you have done to yours, makes it so much easier to answer questions. Just like if we knew what lift, what you had added or didn't add would make a huge difference in the response you'd get.
ridenby
Gold Supporter
Kentucky
Regardless,you and your jeep will be happier with 16" wheels. 15" works,it is just so close to rubbing the caliper.
streetglideok
Colorado Springs
I was going to go with 30x9.5, but I've heard some say there is really not a lot of difference in diameter between them and 235/75r15, just a little wider, whereas 31x10.5-15 is going to be a definite increase in size. With 15x7 alloys, I'd really like to see how they compare to what others run.
This site gives a rough idea of tire dimensions, but we all know that different model of tires are actually different sizes.
http://www.1010tires.com/Tools/Tire...16/235-75R15/30x9-50R15/31x10-50R15/245-75R16
Some real life input would be great.
