Problem with 2002 Liberty Electrical
wmerritt72
NYC
I am at my wits end so perhaps someone here can help me. I have a 2002 Liberty Sport 3.7L V6. When driving on the highway at aboul 15- 20 miles in the battery indicator has started coming on. I Have visted the dealer and had the Battery and the Alternator changed, but the problem perisist. It happens no matter what is running on the electrical system. Also, it never seems to happen while driving short distances locally. Is there something else I should try looking into besides the Battery and Alternator? Any help would be appreciated.
thanks
NomadKJ
Denver, CO
Try hooking up a voltmeter or ampmeter to the charging system.
Voltage: 13.8 -14.8VDC
Charging amps: +
Discharging amps: -
wmerritt72
NYC
When my mechanoc Checked before it was charging between 12.75 and 13. The biggest problem is that When I take the truck to the dealer or a mechanic, the real big problem never happens. The mechanic even drove it around all day and it did not occur. Yet when I drove it a few miles to the mall, it happened again. Could somethig be overheating and causing this?
abarkl
Pull the fuse, bulb, or get out the electrical tape and cover the light!
I know what it is, your driving to the mall. :-s
valvestem
Northeast US
Voltage
12.75-13 volts is too low of an output, it should be closer to 14-14.4
wmerritt72
NYC
After puyrchasing a new battery, alterneator and service manual. I am about to conclude the problem may be with the PCM. Since the voltage regulator is integrated into the PCM I may need to replace it. I am guessing this is what it could be based on the Servoce manual.
