trevorsmith
i am new to this forums but have had my liberty for years. the power steering started leaking a couple years ago and i took it in because i had no time to fix it myself. they changed out the high pressure hose and everything was fine. then it started leaking again and they changed out the line again saying the first one was defective. long story short its on its 5th line now and ******* power steering fluid everywhere. i am going to replace the pump and the line myself this time and see if that fixes it. do you guys think this is the right course of action? what would you guys do in this situation? the new pump does not come with the reservoir on it is that hard to change over to the new pump? also in the service manual it says to remove the cooling fans and stuff, is this necessary or can it get the pump out without removing all that stuff?
