Post Lift ?
KJedmonton
Edmonton, AB, Canada
So now that I have put a few KM's on the lift I just had 2 questions for everyone...
1 Is it normal that after my lift I now have tire rub at full lock, when pre lift I did not (same wheels/tires)
2 How long before the lift settles out enough to so that the spindle no longer makes HARD contact with the bottom of the strut bump stop thingy when I go over bumps, I can live with it but I just don't want to do damage!!!
This is were its making contact...
Thanks all
James
Take it out somewhere and romp on it, twist it up good and get the springs settled in. Go over some hills and it will get everything settled in good.
Also when you lift you actually pull the front tires inward some so that will make a difference as well rubbing inside
RenegadeMarine
Fraser, MI
Pre-lift my tires (245/70/16) would rub at about 3/4 lock, now with the lift on I get no rubbing at all.
