oily in water coolent
theuns mienie
sout africa
hi
2004 jeep cherocee crd limited,my jeep loose water and no water leak ever second day i must fillup water in resevoir,and then the water cap look like oil slush in the resevoir .please can some body help me with this problem
NJallDAY
New Jersey
Yea sounds like a blown head gasket to me. Not good.... if your handy you can do it your self but its not the easiest fix for a novice
Billwill
White River, South Africa
hi
Probably blown head gasket but the oil cooler is water cooled and there could be a cross-contanimation of oil/water in this area too....have a good look at the oil cooler at the front/bottom of the engine where the CAC and radiator are located.:freak3:
Billwill
I saw on another CRD forum,Lost I think, that someone had a similar problem with a suspect blown head gasket and fixed it with "Bars Leak Sealant"
I do not trust these sealants too much but maybe it is worth a try before having an expensive head job done!
