Oil light On, Oil light Off.
JK2KJ
Toronto Canada
I recently purchased an 04 renegade. First thing I did was take it for an oil change cause the oil light was on and who knows when that last oil change was. So I get my jeep back oil light still on I reset the km for oil change turn off the jeep turn it back on and its gone. Basically the oil light will stay on after I start the Jeep about 50% of the time but everything seems alright. Are there any sensor problem or anything else it could be.
jnaut
Seattle
Oil light on, Oil light off, Oil light on, Oil light off.
We call that "blinking".
Sorry, couldn't resist.
JK2KJ
Toronto Canada
No its not blinking Like I said It will stay on about 50% of the times that I start it up and other times its fine I can turn it off and start it back up right away and then it will be back.
jnaut
Seattle
I know JK, I was just razzin' ya. That actually comes from a Venture Brothers show where Dr. Venture is asking his kids what the status of the 'problem' light is. One yells "It's on" the other yells "It's off!" then the first yells "Now it's on!" the second yells "Now it's off!"
Dr. Venture yells back "That called 'blinking' boys!"
KeswickDave
Gold Moderator
Queensville, Ontario
I've recently been seeing the same thing - oil changes are up to date and level looks fine, but sometimes when I start the Jeep cold, the oil light comes on and stays on.
I can start it for a minute, shut it off and the light will be off.
Seems to do it more often when it's colder outside.
Has me a little worried, I hope it's just a sensor (no warranty here).
JK2KJ
Toronto Canada
Hmm It does happen when its a bit colder outside and I tryed running it for awhile turning off and re-starting it and it also disappered. Ill be heading to the dealership next week and see what they say.
KeswickDave
Gold Moderator
Cool, let me know how that turns out!
sxmd
baltimore
I recently started having the same problem. If anyone gets a fix, post it so we can see the results. I suspect it is the sender, but I would like to know for sure, so when I buy the transfer case position sensor, I can buy the oil pressure sender at the same time.
JK2KJ
Toronto Canada
I have an answer passed by the dealership last week told him the problem. Right off the bat they said it wouldn't be covered under the extended waranty so they would need to charge 30 min for inspection. They Checked it out and told me it was an Oil Pressure switch and would be 30 min of labour and $30 for the part. They went ahead with the job.
Details
FP number 05149097-AA
Description
Switch 08-058-060
Unit Price $24.75 CDN
Labour
30 Min Inspection
30 Min Job
$109.95
Walked out with a $152.22 CDN Bill Taxes Included
Not horrible but im sure some one with a mechanics background can figure it out for them selves and save they stealership costs.
Good Luck
sxmd
baltimore
Yellocoyote,
What tool did you use to get the switch out? The 1 1/16 12 point socket seems to big to fit and I can't get a 1 1/16 wrench in. I suspect I will need a 6 point socket to get it out. Am I right?
Thanks for your help. A friend works for a dealer and I got the switch for $10.00.
Sxmd
offrovering
oh
I have replaced 3 oil sensors on various chrysler vehicles, the last time it was an updated sensor.
offrovering
oh
Yellocoyote,
Sxmd
they make sockets for oil sensors or 02 sensors, allows for the harness to get through. I just break the harness off and use whatever gives me some grip since the sensor coming off is bad anyway.
here you go: http://www.sjdiscounttools.com/kd41720.html
gives you an idea
yellocoyote
NW Chicagoland
Yellocoyote,
Sxmd
I believe it was a deep 30mm socket. I'd have to check again though. The sensor connector is behind the hex head. They designed the hex head that large so the socket would fit over it.
