Oil filter: design flaw in 02 CRD
ascas
Slovakia
Hello all!
I'm not sure if this is valid to the non CRD Jeep KJs, but I think there is a design flaw with the oil filter placement on the 2.5 Diesel version (my 2002).
As you can see on the attached images, a screw from the body damages the filter. If the car is in a stationary position (eg. when you change the filter) there is about a 5 mm (0.2 inch) clearance between the problematic screw and the filter body. However as I suspect, when you drive the car the chassis is subjected to - not so - slight deformations, which may damage the filter.
Has anyone else noticed this?
Do you think that the problematic screw might be shortened, or is the screw a special one used for lubrication?
ascas
Slovakia
WOW! That's a good amount of flex and damage to have started out with 5mm clearance. Is something else loose that could be causing the 'flex'?
I don't think so. I also think is possible that when driving, the chassis / suspension (or certain parts) deform that much. Especially if I think about deformation in resonance modes.
(I've tried to take a picture of the problematic part, but its all wet outside and I did not really want to climb under the car... )
The drivetrain(engine,trans,and t-case) are suspended by "motor" mounts which soaks up small vibs so they are not transmitted to the interior and keep the uni-frame from "flexing" from the engines torque.The engine will want to turn clockwise(as from the drivers seat) when you press down on the stupid pedal from the torque.
ascas
Slovakia
I would say the engine is not the sole source of the possible vibrations. According to theory even a good old shock will excite all modal frequencies and shapes. Although the engine is a very good vibration exciter itself:) I will check the mounts.
And ooooh, sorry about calling 'it' a car. I will go into the corner, no dessert and TV for a week. :)
