seabass1858
I am consuming oil somehow and it is collecting in the vacuum lines. I went through 3 pcv valves in the 10k miles that I put on it and have to keep topping the oil off every other week. It is not smoking blue so I know its not the rings, and the crank case vent isnt clogged, and it is not leaking oil anywhere, but something is causing it to suck oil in my vacuum lines. The jeep only has 90k original miles, I just did another oil change and put this engine restorer stuff in it to see if it helps.
