OEM roof lights hardware
bladerunner555
Missouri
The local 4x4 parts place gave me an estimate of over $600 to install the lights.
So I am going to do it myself.
I need to know the size of screws,nuts,bolts,rivets,washers,whatever needed...?
bladerunner555
Missouri
Never mind
I am not going to risk the rain and rust
Any one want to buy a OEM Jeep Liberty Renegade roof light?
bladerunner555
Missouri
My idea of "correctly" might not be the same as theres.Either way,I am going with a different option.
bladerunner555
Missouri
Been thinking of installing a roof basket and than attaching lights to that.Yeah,it will probably require drilling,but I'd rather have it be only 1 hole,where as with the OEM lights,it would be at least 4 holes drilled,plus one hole cut(for the wiring).
First how many lights will you have up there
All on same switch or two or more switches ?
Next ground can go to one of the bolts that hold rack on, grounds good there
Next the weather stripping that run up the side of the pillar beside the windshield has small screws hidden in behind, remove those , run wiring in behind that weatherstripping , up to the area at rear of door, if done right no wiring shows and all works well
But I've only done 6-7 like that so more than likely to some on here I'm doing it wrong LOL
bladerunner555
Missouri
Is there any thing I can use to keep the wiring from coming uncovered by the weather stripping?
And than to get the wiring in to the vehicle(so i can connect the switch),i go through the firewall?
bladerunner555
Missouri
done
no hardware needed
