No sound on the right side!
TwitchRider
Newmarket
Hello,
Here is what I have done to date to troubleshoot this issue.
- taken front speaker (w amp) and tried it on the left side: it works fine
- I have done a continuity test on the wires from the radio to the right speaker: all wires were ok
- swapped out the radio: still no sound on the right side
Is there a power lead or ground that i should be checking around the right side front speaker? I'm a little stumped.
Thx,
Q
VeitzJeep
Virginia Beach, VA
Check your fuses. It's so trivial, but it's often overlooked. My front power outlet seemed like it had a bad connection, but turned out the fuse was bad but a spark was arcing accross. New fuse, problem fixed. They often blow when you mess with any wires.
Jo6pak
Left coast of WI
Is it possible that your amp is bad, maybe a bad channel?
Is it just the front speaker, or all right side speakers?
I'm guessing the amp got disconnection, and or the speaker too.
TwitchRider
Newmarket
Hello,
Thanks for the help. I know we can get this fixed.
- fuses have been checked & all are ok
- I'm going to say that the amp is fine. I swapped it with the left side & all (left) speakers worked fine
- I have gone through & ensured that all connections are good
gdherrera
Hillsboro
Bump,
I'm having the same exact problem but it seem to work when don't tighten the speaker all the way to down which leads me to believe that its a wiring issue maybe something is getting grounded.
the only difference is that mine is on driver side.
i know the speaker is blown so will replacing the speakers and using the stock amp fix this?
jguthrie
Bay Area, CA
Is it an old amp that has a balance potentiometer? Possibly set to max left while tuning? ;)
Otherwise, I say ground somewhere.
TwitchRider
Newmarket
Update
Hey KJ's,
Ok here is the update. It is the Radio Choke. The "Wonderful" engineers @ Chrysler have installed a relay (aka radio choke) that controls the power feed to the premium speakers. When u turn the radio on...the relay activates & the speakers power up. I really think it would be better if they just had regular head units...sooo much easier. I have ordered 2 replacement relays from e-bay & we will see if i get sound back on both sides. I will let u know how it goes.
Q
mmc757
Norwich, CT
I just replaced everything when I had this problem. HU, wires, and speakers. Took everything Chrysler completely out of the equation.
I do remember looking at the wiring diagram and suspecting the choke, but decided just to nuke the problem instead of going for the precision strikes.
TwitchRider
Newmarket
It's Fixed!!!!
OK....I spent the afternoon and rewired the positive & negative feeds to the speaker. I now have sound.
8gti9
Fort Carson, CO
Hello, driving back from minnesota and all of a sudden the front pass speaker goes out on my '03 liberty. Checked the fuse and took out the radio to check the connector on the back of the radio, everything looked ok.
Can anybody pls guide me on where this so called "radio choke relay" would be located at.
thnx
