new member 08 kk lift
jcook79
new member, just wanted to thank all the knowledgable folks here. i completed my 2.5" ome/bilstein lift by researching past threads, so much information here!
AFT2008KK
So what was the final part list? Ant leads on sourcing the parts? Looks good btw
Dirtyrat
I have at least 4” of lift on mine. If the ride is a little harsh, you can remove the front sway bar. It does help. I also have a subframe drop. Purchased from a local machine shop. 2” round stock, 1” high and a 5/8 hold in the center.
I would modify the above, you can remove the front sway bar *off road*. Removing it on road and then needing to do an unexpected evasive maneuver can cause a rollover.
Dirtyrat
I have no issues in it’s handling
jcook79
thank you. used ome 927/ bilstien 24-139168 on the front, ome 731 with bilstein 24-185660 on rear. got extended bump stops of questionable quality on front from ebay. on the rear i used hockey pucks. bought a tube from amazon to cut for rear shock bushings. fit perfect, 16mm o.d. with 2mm wall thickness
ReniTheRenegade
Little Rock, AR
Do you have the amazon link for the bushings?
