Need your opionions on this. tow hook mount idea.
Would it work well?
  • No
    Votes: 0 0.0%
  • May not be strong enough
    Votes: 0 0.0%
  • Total voters
Bennett
Active Member
Green Bay
Do guys think I could mount tow hooks between the two upper bolts in this pic? The metal is pretty thick almost 1/4" thick.
Bennett
Bennett
Active Member
Green Bay
lol, if you guys think its a bad idea then I need to know.
But I just measured the metal plate and its 1/4" for sure.
Bennett
2kjhouse
Davis Junction, Illinois
hook placement
Correct me if I am wrong but wouldn't that put your tow hook behind your round tube? I think this would be a problem if you were unable to get or see under the vehicle, but that would only apply if your front end was buried in mud or water i guess. JMO
Bennett
Active Member
Green Bay
The tow cable would go above the round tube, so the round tube bar kinda helps it from getting buried in a way. But the round tube isn't directly in the way of where I want to put the hook, so there is clearance for the tow cable and the ability to connect it.
Bennett
quivvy
Chicago, IL
if that is bolted on to the frame it may be ok. i just know factory hooks have 3 bolts and you have 2. although wrangler hooks have 3. maybe if you bolted it and welded it? just a thought?
Bennett
Active Member
Green Bay
Re: hook placement
Ok, as recalled, you mounted your hooks on your brushguard, do you have any trouble with them strength wise? I would bet the mounts are pretty similar on the brushguard, mine has a plate that goes above in the frame and it basically sandwitches the frame between two plates of steal.
THANKS!
Bennett
2kjhouse
should be good
Yeah I think mounting through the 1/4 inch steel should be ok, I mounted mine through the 2 1/4 plates and have had no strength issues. I have already had to use them to pull myself out of the mud when I hung it up on the tree. I try to pull across my brush bar rather than from one side though, just to have the whole bar acting as one piece not pulling on side from the rest of it. I also have the same rating on my hooks 10k per hook, the KJ is only around 4k so you should always be fine. =D>
PS i don't think welding them on is necessary or a good idea imo, what if you needed to get the brushbar off or to cange out your hooks later on for something better (like a winch setup) I am still trying to fab up a winch bar to fit in there somewhere on mine. :-k
