need help
possumshole
gastoina nc
i have a 04 kj that ran hot due a cracked radiator then the water pump went then the head gaskets i changed everthing i am still having over heating issues i crack the the plug on top of the engine and let it run it till i don't see any air bubbles to bleed the air out i checked the comperssion it was good all the way around i need some help i am no sure what to do now
NJallDAY
New Jersey
Have you flushed the coolant system? Maybe its gunked up and not allowing proper coolant flow.
possumshole
gastoina nc
flushed the coolant system nothing is gunked up is their a special way to bleed the air out that i don't know of
belvedere
SD
When you had the heads off, were they checked for cracks and warpage at a machine shop?
possumshole
gastoina nc
yup they where checked by a machine shop but i figure out that the fan wasn't working at low speed just high speed so i am waiting on the fan motor now thanks for the help
