My 2003 KJ 2.8 CRD and its problems
Geralt
FR
Hello,
I bought a 2003 jeep jk 2.8 crd that would not start and it still does not start.
Before selling it the seller could not get it to start, he changed all the sensors, the bcm, the pcm and finally the key, the neiman and the skim.
I have error codes:
P0070
P0190
P0130
P0340
P0520
P1130
P1131
P1511
P1685
With all this, I have enough to do but I like challenges.
Excuse me, my English is bad and I use a translator for communicate...
First clear all the codes, with everything that's been done there is no way to tell if they are current or not, then try to start it and rescan to see what comes up.
Geralt
FR
Ok thanks, I'm waiting for a scanner that I ordered online.
I would come and do a feetback.
Geralt
FR
Arrrrggghhhh...
My scanner is not pulling codes from the dashboard.
But it did pull new codes that it found.
P0051,
P0253,
P0808,
U2200,
P0100,
C2400.
Those are very odd codes, clear the list and try again.
Geralt
FR
Hello all,
Thank you for your answers.
The ECU, skim and key have been changed, everything works perfectly.
I think I don't have the best scanner.
Hello all,
Possibly your scanner is the problem, however the symptoms you are describing sound like a fault on the BUS or a module plugged into it pulling it down. Have you checked all the fuses?
Geralt
FR
Yes I changed the interior fuse box.
The only permanent code is P0253, I think the CP3 pump solenoid is faulty.
That's a good call, probably the original fault that the previous owner missed!
Geralt
FR
Hello,
Bosch pump solenoid changed, but I hear a bzzzzz, is this normal or not?
With the engine not running? No mine is silent, on shutdown there is a hiss/buzz from the solenoid on the left side dumping vacuum.
Geralt
FR
The engine does not run, just the ignition is on.
This is not normal, I have another problem somewhere
Ok thanks.
Have you tried using a little bit of starting fluid? It would be interesting to see if it fires.
Geralt
FR
Yes i using start pilot but without effect on startup.
I'm thinking shifted timing or broken rocker arms.
I ordered This on Amazon.
No it's not I'm afraid, there was an independent garage with one but they finished in Covid.
There are after market systems but they aren't cheap!
I have a friend with a decent Snapon scanner that does just about everything, so a decent garage should be able to help you.
