ShowMe Cherokee
- Joined
- Apr 13, 2024
- Messages
- 5
- Reaction score
- 12
On my daughter's 2010 KK 3.7, I am trying to pull my main battery wiring harness because the battery to starter cable is bad, and I figured I would upgrade the whole thing since I essentially have to remove the harness to replace that cable. So essentially the big three upgrade but probably 7 instead from JeepCables.
I have everything removed except the G100 ground that is under the engine and behind the oil filter. How the f**k are you supposed to get that bastard off? I can barely see half the nut if I snake a light down there, but not sure how to get to it with a socket. Do I have to remove the oil filter? Will I be able to see it from under the front then? I can barely reach it by feel from the top by following it from the harness but have no idea how to get a tool on it. It almost seems like you have to lift the engine partway out to reach it.
I would really like to actually remove it, but I may settle for cutting it and just bolting the new one somewhere else on the engine. Any advice from someone that has done this would be very appreciated.
