Loud front-end?
deliciousdaly
Fort Myers Florida
I have an 05 Liberty and my front end was making a crunching noise when I hit bumps that really compressed my front end. So I took it to a shop where they told me I needed shocks, struts, and tires. So I figured why the hell not, so I bought rusty's a suspension lift kit that included the socks and struts. My car still makes the same crunching when I hit large bumps. Any ideas??
hyde
When it is cold outside? or regardless of weather? Search for sway bar bushings. $5 fix.
jnaut
Seattle
I believe several people have that (I am one) and it's been identified as the control-arm bushings.
The jury is still out if it's a problem, or if you should lubricate them. Some people say you should, some people say it will damage them. I haven't touched mine, and I live with the noise. And the noise only occurs when the temperature drops below about 50 degrees. Once the weather warms up, the noise goes away.
hyde
Go down and spray them:
flair1111
usa
same here, i use light sewing machine oil, but i think almost anything might do as long as it wont degrade rubber.
When I do my oil changes and I am under there anyway on a creeper, I spray them. So far, mine are silent.........so far.....haha
well hey, at least you got a decent lift out of their ignorance!
Probably the sway bar bushings as the others have said.
JK2KJ
Toronto Canada
Are there aftermarket sway bar bushing available? Is it safe to continue to drive on them like this?
