Lost Communication with ABS Control Module
DaraBowser
Ontario
DTC Code UO121, 2006 CRD with CAN-bus. After serveral Wheel sensor replacements and wiring investigations, I replaced the ABS module with a Jeep OEM part. Runs and stops but no ABS, Speedo Ands tach are dead now as well. Suggestions?
Have you checked the fuses since you swapped the module?
Also try swapping back, might not work if it's out of a later or earlier Jeep.
