Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
If I wanted to replace some or all of the hydraulic lifters in my 3.7 do I need to find TDC and hand crank as I go or can I just use the valve spring compression tool to gain access and replace one by one?
Thought that may be the case. Thanks for the reply! May leave this up to my shop. I've not done engine internals before unless you want to count spark plugs.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
