Left headlight and ventilation fan problems
DiegoND
Northern Indiana
I recently noticed that I was driving with one headlight out so I went to change the bulb out but it didn't fix the problem. I checked the fuses and still all are fine. Does anyone have experience with this phenomenon? Also the fan on my heater only blows when turned to 3 or 4 but only blows on high (in case you can add to the response)
2005 Liberty
six speed manual
Ry' N Jen
Did you check both the low beam and high beam relay?
It's in the Junction Block, which if I recall correctly is behind the lower part of the dash board below the steering column (Knee kick panel) on the left side. Front right corner.
A micro relay.
There are four screws behind the trim panel/bezel that hold the Junction Block.
If my babbling/description doesn't make any sense... Maybe somebody else can elaborate this info more clearly for you!:eek:
The high beam head lamp relay is located behind the panel that pop's off (from the bottom) on the drivers side of the dashboard. Again, a micro relay.
Other than that, maybe you have a bad bulb. (I know you replaced the bulb, but It has happened to me! New package but faulty bulb!)
As far as the blower, check here:
http://www.jeepkj.com/forum/showthread.php?t=26012&highlight=blower+resistor
Remember, search function is your friend!
DiegoND
Northern Indiana
Thanks I had a problem somewhere between the left low beam fuse and the connector so I ran a whole new wire. I checked the schematics and saw there were no splices or other connections that I needed to find so it has a new wire. As for the fan I took it to the shop.
Thanks
