KJ -What is on Your Spring Check List?
Porkchop
Troy Mi
I USED TO BE ADDICTED TO THE HOKIE-POKIE...BUT I TURNED MYSELF AROUND Isn't that what's it's all about. LOL
wheeee32
Not the mountains.
1. Replace passenger front hub.
2. Replace passenger cv axle.
3. Replace passenger intermediate shaft.
4. Replace heater resistor pack.
5. Pound out pinch welds.
6. Clean up any corrosion found.
kage860
Westchester, NY
I need to do my 60k maintenance soon which I will:
Replace Spark Plugs, put coppers in at 30k, going to try Denso Iridiums this time (coppers were worn out badly at 30k)
Replace front and rear diff fluid, synthetic
Replace Transfer Case Fluid, Trans Fluid and Filter
Replace Air Filter
Inspect PCV
Inspect Brakes, I have Raysbestos Professional Grade Ceramics if I need them
Today was busy..
Up On lift..replaced the organic pads to Oem Ceramics..much better!
Ya the blue things are SpiderTrax Wheel Spacers..
48994[/ATTACH]"]
Got to use Silicone Spray on all the Boots & bushings etc..no squeaks now.
48996[/ATTACH]"]
Painted the Oil Pan after a Quick Brushing...
48998[/ATTACH]"]
17" Chrome Clads cleaned inside using SOS pads & Simonoiz heavy duty wheel cleaner!
49000[/ATTACH]"]
Also checked ATF+4 fluid level though the Transfer Case Fill plug..all good.
I think I'm good to go for summer now!
49002[/ATTACH]"]
