Keeping undercarriage rust-free???
OldJoe
Gurnee, IL
A friend at work just bought a truck that’s about 25 years old. It spent most of its life in Texas but for the last few years, it was in Ohio. Friend looked at the frame, etc. and there was nearly rust free. He also looked at a car the seller has had in Ohio well over 15 years, also with little or no rust. Seller said he sprayed Auto Trans Fluid on the frame, axle, etc. every fall and this keeps it looking new. Friend said the brake lines and clips look like new. Now, I know ATF and acetone makes a great penetrating oil, but has anyone out there heard about ATF for undercoating? Any comments???:shrug:
RenKJ
Canada
Never heard of that, but i could see atf being really good penetration wise, i mostly use rust check, combination of the red or green stuff depending on season and area, during winter i clean it well and use the green stuff all over
Interesting, the old school undercoating days used an oil spray, so I guess a DIY ATF would be along the same idea.
What ever works I suppose. I Don't want a fire issue or sticky oil/Atf everywhere on the Jeep though.
When I got my Jeep, I originally got it undercoated with a teflon based paint/undercoat.
54460[/ATTACH]"]
Since the undercoating, I use a rust spray paint to keep it in top shape.
54462[/ATTACH]"]
The front often needs touch ups too.
54464[/ATTACH]"]
Of course the oil pan needs to be kept clean & painted, otherwise it can be a bad cancer day.
54466[/ATTACH]"]
belvedere
SD
I started using Corrosion Free, which is applied every 18 months.
renegade 04
Albany New York
I got my libby undercoated by the local ziebart place, then I put eastwood internal frame coating on the inside of the uni-frame rails.
Hockeygoon
Manhattan Kansas
Have leaky transmission and keep adding fluid. Going down the road 70 MPH will leave a nice fresh film on everything.
RenKJ
Canada
Didn't know about that internal stuff, gonna add it to my spring work, would you mind doing a post on the spots you stuck it through, I only know of a couple running along the sides
renegade 04
Albany New York
I just sprayed it in any opening on the frame I could find. I also put masking tape over the holes where I was not spraying so that the paint did not get on the driveway.
Staff online
