Ignition switched power - cargo area
Ohio-white-kj
ohio
Anyone know if/where there is ignition on power source in the rear anywhere?
I know I can run from the front - just lazy in case something already there. Have the factory tow hook up as well, and a service manual.
2005 - Libby
There's a 12V ignition on power source on the trailer wiring.
If you have a mopar trailer wiring set up, there's a wiring diagram on the spring loaded cover.
Ohio-white-kj
ohio
Mines a MOPAR - at least 99% sure as I hear the relays, it also had a MOPAR hitch added (2nd owner) .
What is this spring loaded cover? AFAIK you need to remove that right-hand cover panel for access. I'll admit I have not spent much time lookng...yet.
Ohio-white-kj
ohio
Yeah --- mine only had the 4 pole flat pigtail installed, but does have the mount for the round one...
I'll just pull the panel off, will probably add the other pig tail as well while in there.
Going to wire up a rear facing dashcam.
Thanks
Ohio-white-kj
ohio
OK - back at this.
Tore the panel out. The relay that is supposed to be ign in/out has no power. Diagrams show fuse 30 under the hood - 30 is there and OK, as well as one under the dash that also is for some other items - also OK.
Anyone have another suggestion?
