Ok I just bought a 2002 Jeep Liberty Sport 3.7 2wd.
The check eng light was on when test drove it. Lot said they would fix. I came back light was off and the shaking at idle was gone. I bought it. 2 days later the light came back.
This is what it does. turn jeep on its idle ruff check engine light blinks. The jeep will warm up then I turn it off and back on and the light stops blinking and stays solid but the idle is smooth and I have full power.
Had the check engine light looked at it sys its a misfire on #6. The lot said they replaced the coil pack the first time. They said to drive it 500 miles to see if it clears up if not they would put in a new injector.
They said they tested the compression and that it was good.
Any Ideas? Has anyone else had this problem?
