How to Test and Repair the Cruise control on a Liberty 2.8L - Suggestions, recommendations and if po
Is anything else not working?
Arnold Meiring
Hi,
All is working on the Jeep Liberty 2,8L CRD, just the Cruise Control is dead... not even the dash indicator for the CC is on. Seems like a no power situation on the CC. Any help will be appreciated. I am totally new to Jeep as I previously had Land Rovers.
I moved over from Land rovers too, I don't see why they command such high prices, my Jeep is easily the equal of Discovery, and it doesn't melt as fast on the salty roads!
Have you downloaded the manuals in the link above? All the wiring diagrams are in there.
Just a thought if you have recently bought the Jeep, has it ever worked? Just wondering if someone has put a steering wheel on from a different car? The Limited ones have it, not sure if it was fitted on other cars.
lorraine 54
Salut,
Tout fonctionne sur la Jeep Liberty 2,8L CRD, seul le régulateur de vitesse est mort... même le voyant du tableau de bord du CC n'est pas allumé. On dirait qu'il n'y a pas d'alimentation sur le CC. Toute aide sera appréciée. Je suis totalement nouveau chez Jeep car j'avais auparavant des Land Rover.
Bonjour
capteur de roue hs !
ecu non programmé !
capteur pédale freins !
touche volant régulateur
serpentine
j"ai le meme probleme acheté occasion régulateur fonctionne pas ! et toujours pas trouvé la panne !
